Zum Hauptinhalt wechseln
Erkennen und Trennen von Kabelverbindern
Englisch
Deutsch
Schritt 5
Recognizing & Disconnecting Cable Connectors, Flat-Topped (Low Profile) Connectors: Schritt 0, Bild 1 von 3 Recognizing & Disconnecting Cable Connectors, Flat-Topped (Low Profile) Connectors: Schritt 0, Bild 2 von 3 Recognizing & Disconnecting Cable Connectors, Flat-Topped (Low Profile) Connectors: Schritt 0, Bild 3 von 3
  • Some connectors have a flat, plastic top that sits flush on top of their socket. Often, these connectors have multiple cables connected to them. Flat-topped connectors are usually on the larger side, and are typically used to connect batteries in laptops and larger gaming devices.
  • To disconnect the cable, use the flat end of a spudger to lift and unclip the outer edges of the connector. You may need to use your fingers to pull the connector completely out of its socket.
  • Sometimes, these connectors have a slide lock running across the top that holds the connector in place. If this is the case, push the lock away from the connector before trying to disconnect it.
  • Flat topped connectors can also have a metal locking bar that keeps the connector in place. Unclip and flip the locking bar up to disconnect it.
  • To reconnect the cable, carefully position the connector over its socket and press straight down—the connector should snap into place without much force. If you're having trouble, the connector is most likely misaligned. Reposition it and try again.
  • Don't try to force the connector into place or you may damage the delicate pins.
Bei manchen Steckern ist die flache Oberseite mit Kunststoff beschichtet, die unmittelbar mit dem Anschluss abschließt. Meistens sind viele Zuleitungen daran angeschlossen. Die Kabel gehen auf der breiten Seite hinein, sie werden typischerweise zum Anschließen von Akkus in Laptops und größeren Spielkonsolen verwendet.
Um das Kabel abzulösen, hebe den Stecker mit dem Spudger an den Kanten hoch, bis er sich löst. Eventuell musst du ihn dann mit den Fingern ganz aus dem Anschluss herausheben.
Manchmal ist der Stecker mit einer Schiebearretierung über der Oberseite gesichert. In diesem Fall musst du die Arretierung erst vom Stecker wegdrücken, bevor du den Stecker abtrennen kannst
Flachverbinder können auch mit einem Sicherungsbügel aus Metall befestigt sein. Du musst den Sicherungsbügel erst lösen und aufklappen, bevor du den Stecker abtrennen kannst.
Um den Flachstecker wieder anzuschließen, musst du ihn erst sorgfältig über dem Anschluss ausrichten und dann gerade nach unten drücken. Der Stecker sollte ohne großen Kraftaufwand einrasten. Wenn das schwer geht, sitzt der Stecker meistens nicht richtig. Richte ihn neu aus und versuche es nochmals.
Drücke den Stecker nicht mit Gewalt ein, die Kontakte sind empfindlich und können leicht beschädigt werden.
