Zum Hauptinhalt wechseln
케이블 커넥터 인식 및 연결 해제
Englisch
Koreanisch
Schritt 6
Recognizing & Disconnecting Cable Connectors, Press Connectors: Schritt 0, Bild 1 von 3 Recognizing & Disconnecting Cable Connectors, Press Connectors: Schritt 0, Bild 2 von 3 Recognizing & Disconnecting Cable Connectors, Press Connectors: Schritt 0, Bild 3 von 3
Press Connectors
  • Press (or "pop") connectors are found at the end of a ribbon cable and have a flat, metal or plastic top—typically rectangular. These connectors are extremely common in smartphones and laptops, and connect a wide variety of small to medium-sized cables—screen, battery, board interconnect, etc.
  • Place a spudger or an opening tool under the connector's edge and pry straight up to disconnect it.
  • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
  • Work carefully: don't pry on or accidentally scrape any small, surface mounted components on the board.
  • Although more rare, some larger pop-style connectors might have a built-in pull-tab for easy disconnection. Lift straight up to disconnect these.
  • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  • Don't press down on the middle of wider connectors until they're fully seated. If misaligned, the connector or the pins underneath can bend or break, causing permanent damage.
더 작은 압착 (또는 "pop/팝") 커넥터는 플라스틱 여는 도구, spudger/스퍼저 또는 손톱으로 슬쩍 튕겨주면 됩니다.
도구의 끝을 커넥터 가장자리 아래에 넣고 소켓에서 커넥터를 똑바로 들어 올리세요.
소켓 아래가 아닌 커넥터 가장자리 아래 들어올려야 합니다. 소켓 아래를 들어 올려 회로 기판에서 소켓이 빠지게 되면 특별 미세 납땜 기술과 도구로 수리해야 합니다.
다시 연결하려면 커넥터를 소켓 위에 조심히 맞추고 제 자리에 클릭하며 들어갈 때까지 손가락 끝으로—한 쪽 먼저, 그리고 나서 다른 쪽—누르세요.
커넥터가 완전히 장착될 때까지 커넥터 가운데는 누르지마세요—잘못 맞춰진 경우 커넥터가 구부러지는 영구적인 손상을 입을 수 있습니다.
