Zum Hauptinhalt wechseln
케이블 커넥터 인식 및 연결 해제
Englisch
Koreanisch
Schritt 7
Recognizing & Disconnecting Cable Connectors, Coaxial Connectors: Schritt 0, Bild 1 von 3 Recognizing & Disconnecting Cable Connectors, Coaxial Connectors: Schritt 0, Bild 2 von 3 Recognizing & Disconnecting Cable Connectors, Coaxial Connectors: Schritt 0, Bild 3 von 3
Coaxial Connectors
  • Coaxial connectors like these—also called antenna, U.FL, or IPEX connectors—have a metal head that snaps over a circular socket on the board, like a metal snap button on a shirt. These connectors come in various sizes and are often used to connect Wi-Fi or cellular antenna cables.
  • To disconnect the cable, slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
  • If you work with these connectors often, you may want to buy a specialized disconnect tool (small size, large size). These tools speed up the disconnect and reconnect procedures while minimizing the risk of damage.
  • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
  • Reconnecting these can be tricky. Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
  • Don't try to force the connector into place or you may permanently damage it.
U.FL 안테나 케이블 커넥터 같은 소형 동축 커넥터는 얇은 ESD-안전 도구 또는 핀셋을 전선 밑으로 커넥터에 닿을 때까지 밀어 넣고 보드에서 똑바로 들어 올리세요.
다시 설치하려면 커넥터를 제자리에 맞추고 조심히 똑바로 누르세요. 커넥터는 재킷의 금속 단추처럼 소켓에 "끼워집니다".
[title] Coaxial Connectors
-[* black] For small coaxial connectors, like these U.FL antenna cable connectors, slide a thin, ESD-safe pry tool or tweezers under the wire until it's snug against the connector, and pry straight up from the board.
-[* icon_reminder] To reinstall, hold the connectors in place and gently press them straight down. The connectors “snap” into their sockets much like the metal snaps on a jacket.
+[* icon_note] Coaxial connectors like these—also called antenna, U.FL, or IPEX connectors—have a metal head that snaps over a circular socket on the board, like a metal snap button on a shirt. These connectors come in various sizes and are often used to connect Wi-Fi or cellular antenna cables.
+[* black] To disconnect the cable, slide a thin, ESD-safe pry tool or [product|IF145-020-5|angled tweezers|new_window=true] under the metal neck of the connector (as close to the head as possible) and ***lift straight up*** from the board.
+ [* icon_note] If you work with these connectors often, you may want to buy a specialized disconnect tool ([product|IF145-558|small size|new_window=true], [product|IF145-557|large size|new_window=true]). These tools speed up the disconnect and reconnect procedures while minimizing the risk of damage.
+ [* icon_caution] When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
+[* icon_reminder] Reconnecting these can be tricky. Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
+ [* icon_caution] Don't try to force the connector into place or you may permanently damage it.
