Zum Hauptinhalt wechseln
Motorola DROID MAXX Basic Teardown
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 4
Motorola DROID MAXX Basic Teardown, Removing the Camera Back Housing: Schritt 0, Bild 1 von 3 Motorola DROID MAXX Basic Teardown, Removing the Camera Back Housing: Schritt 0, Bild 2 von 3 Motorola DROID MAXX Basic Teardown, Removing the Camera Back Housing: Schritt 0, Bild 3 von 3
  • Lay the Droid Maxx face down on the plastic surface to start removing the screws.
  • Take the Torx T5 Screwdriver and carefully remove all the screws in the Droid Maxx’s motherboard. Note that there is a total of eight (11) black screws spread across the motherboard, four (4) at the top and four (4) at the bottom, and also two (2) silver screws located to the right lower part of the Droid Maxx.
  • There is(1) screw holding the camera housing. Use a T4 screwdriver for this one screw.
  • After removing all the screws, lift hold the Droid Maxx as in step 2
  • Locate two (2) tabs in the camera plastic housing , one (1) at each corner of the Droid Maxx
  • Take the Flathead driver and gently lift both tabs to release the camera housing. Be careful because these plastic tabs are very delicate and can break easily.
Hier Übersetzung einfügen
