Zum Hauptinhalt wechseln
Motorola DROID MAXX Basic Teardown
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 3
Motorola DROID MAXX Basic Teardown, Removing the Back Cover: Schritt 0, Bild 1 von 3 Motorola DROID MAXX Basic Teardown, Removing the Back Cover: Schritt 0, Bild 2 von 3 Motorola DROID MAXX Basic Teardown, Removing the Back Cover: Schritt 0, Bild 3 von 3
  • Tilt the Droid Maxx towards your right so you can see the edge of the rubber back case and keep this position.
  • Take the Spudger and press the tip against the space between the rubber case and the Droid Maxx frame. Slide the Spudger’s edge along the surface until you hear a “snap” sound.
  • Work your way to the top of the Droid Maxx with the Spudger and use your holding hand’s fingers as support while you remove the upper part of the rubber back case. Rotate the Droid Maxx to facilitate your movement if necessary. Do not go along the bottom to remove the case.
  • Once the top part of the case is separated from the frame, grip the bottom part of the rubber case with your finger and slide the case down to remove it completely.
  • Place the rubber back case in a nearby place where it will not interfere with your arms motion.
Hier Übersetzung einfügen
