Zum Hauptinhalt wechseln
Beats Pill 1.0 Hauptplatine austauschen
Englisch
Deutsch
Schritt 3
Beats Pill 1.0 Motherboard Replacement: Schritt 0, Bild 1 von 2 Beats Pill 1.0 Motherboard Replacement: Schritt 0, Bild 2 von 2
  • Remove the motherboard from the tabs and gently lift it out of the case.
  • Remove the yellow NFC module that is attached to the motherboard from the plastic casing with tweezers.
Hebe die Hauptplatine vorsichtig aus dem Gehäuse. Entferne auch das gelbe NFC Modul mit einer Pinzette.
-[* black] Remove the motherboard from the tabs and gently lift it out of the case. Remove the yellow NFC module that is attached to the motherboard from the plastic casing with tweezers.
+[* black] Remove the motherboard from the tabs and gently lift it out of the case.
+[* black] Remove the yellow NFC module that is attached to the motherboard from the plastic casing with [product|IF145-020|tweezers].
