Zum Hauptinhalt wechseln
New Nintendo 3DS XL (2015) 메인보드 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 9
Nintendo 3DS XL 2015 Motherboard Replacement: Schritt 0, Bild 1 von 3 Nintendo 3DS XL 2015 Motherboard Replacement: Schritt 0, Bild 2 von 3 Nintendo 3DS XL 2015 Motherboard Replacement: Schritt 0, Bild 3 von 3
  • Using tweezers, gently pull the four marked ribbons out of the ZIF connectors along the sides of the motherboard.
  • These ZIF connectors are held in place by friction and do not have locks—lifting the flaps on these connectors will break them!
  • Three of the ribbon connectors have plastic clamping flaps that cover the ribbon to prevent slippage. Use the tweezers to flip them up before ribbon removal.
  • This one ribbon connector may also have a plastic clamping flap, but it's not like the others, rather it's similar to the one used for the Circle Pad. Gently flip up the flap on the side opposite the ribbon cable to remove the cable.
  • This connector was previously listed among the ones that do not have locks, however on most if not all systems, it actually does have one. Trying to remove or reinsert this cable without unlocking it will damage the cable, requiring a replacement of the Touch Screen's digitizer. Fortunately, the LCD uses other ZIF connectors, so that should still be fine.
  • If, on your system, this connector does not have a lock after all, do not pull up on the flap! It should come up easily; if it doesn't, it probably isn't meant to lock, but instead just hold the cable in with friction. In that case, try gently pulling the cable out of the connector.
  • When reassembling the device, be sure to flip the ZIF clamps back down.
  • While the SD card reader is shown as removed in this photo, it is optional for the removal of the motherboard.
핀셋을 사용하여 메인보드 측면을 따라 빨간색으로 표시된 리본 케이블 네 개를 살살 잡아당겨 빼내세요.
이 ZIF 커넥터들은 마찰에 의해 고정되며 잠금 장치가 없습니다. 이 커넥터들의 플랩을 들어올리면 파손될 수 있습니다!
리본 커넥터 중 3개에는 미끄러짐을 방지하는 플라스틱 클램핑 플랩이 있습니다. 리본을 분리하기 전에 핀셋을 사용하여 뒤집어주세요.
이 리본 커넥터 하나에도 플라스틱 클램핑 플랩이 있을 수 있지만 다른 커넥터와 달리, 슬라이드 패드에 사용된 것과 비슷합니다. 리본 케이블 반대쪽에 있는 플랩을 살짝 위로 젖혀 케이블을 분리하세요.
이 커넥터는 이전에는 잠금 장치가 없는 커넥터 중 하나로 나열되었지만, 대부분의 시스템에는 실제로 잠금 장치가 있습니다. 잠금 해제하지 않고 이 케이블을 제거하거나 다시 끼우려고 하면 케이블이 손상되어 터치 스크린의 디지타이저를 교체해야 합니다. 다행히 LCD는 다른 ZIF 커넥터를 사용하므로 괜찮을 것입니다.
만약, 시스템의 이 커넥터에 잠금 장치가 없다면, 플랩을 위로 잡아당기지 마세요! 잠금 장치가 있는 경우 플랩이 쉽게 올라와야 하며, 그렇지 않다면, 잠금 장치가 아니라 마찰로 인해 케이블이 고정된 것일 수 있습니다. 이 경우, 커넥터에서 케이블을 살살 잡아당겨 보세요.
기기를 다시 조립할 때는 ZIF 클램프를 다시 아래로 젖혀야 합니다.
이 사진에는 SD 카드 슬롯이 분리되어 있지만, 선택 사항이므로 굳이 분리하지 않아도 됩니다.
