Zum Hauptinhalt wechseln
Hinweis: Du bearbeitest gerade die grundständige Anleitung, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diesen Schritt beinhalten.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Unplug the computer from the power supply before any maintenance or disassembly.
  • Unplug the computer from the power supply before any maintenance or disassembly.
  • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
  • These screws can usually be removed by hand.
  • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
Entferne die zwei 5mm Kreuzschlitz #2 Schrauben, die sich auf der Rückseite des Computergehäuses befinden.
Diese Schrauben können manchmal von Hand gelöst werden.
-[* red] Remove the two Phillips #2 head 5mm screws from the back side of the computer case.
-[* icon_note] These screws can be removed by hand.
+[* icon_caution] Unplug the computer from the power supply before any maintenance or disassembly.
+[* black] Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
+[* icon_note] These screws can usually be removed by hand.
+[* icon_note] Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
