Zum Hauptinhalt wechseln
Canon EOS 60D Motherboard Replacement
Englisch
Koreanisch
Schritt 2
Canon EOS 60D Motherboard Replacement: Schritt 0, Bild 1 von 2 Canon EOS 60D Motherboard Replacement: Schritt 0, Bild 2 von 2
  • Use a plastic opening tool to lift the small hinge holding the circled gold ribbon in place, then gently slide the ribbon out of the socket.
  • Use cation, and pull the ribbon straight out. If damaged the camera may not work the same after reassembly.
  • Next unscrew the three 4.3 mm Phillips #PH00 screws holding the motherboard down using the PH00 screwdriver.
Hier Übersetzung einfügen
