Zum Hauptinhalt wechseln
Canon EOS 60D Motherboard Replacement
Englisch
Koreanisch
Schritt 3
Canon EOS 60D Motherboard Replacement: Schritt 0, Bild 1 von 2 Canon EOS 60D Motherboard Replacement: Schritt 0, Bild 2 von 2
  • Next the wires are able to come off.
  • The RED arrows indicate a small hinge locking the wire in. To remove the wire, follow the same steps taken to remove the wire in the prior steps.
  • The ORANGE markers indicate that you need to lift the wire up and off of the motherboard. Using the opening tool, follow the same steps used to remove the swivel screen wire.
  • Next it is recommended that you use tweezers to carefully remove all hinged wires as demonstrated by the YELLOW arrow on the second image in this step.
  • It is crucial that you move slowly and carefully! If one of the wires gets damaged, the camera might not work properly after reassembly.
  • You must carefully remove these wires by pulling them straight out of the socket they're seated in.
Hier Übersetzung einfügen
