Zum Hauptinhalt wechseln
DigiLand DL701Q Battery Replacement
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 2 übersetzen
Schritt 2
DigiLand DL701Q Battery Replacement: Schritt 0, Bild 1 von 3 DigiLand DL701Q Battery Replacement: Schritt 0, Bild 2 von 3 DigiLand DL701Q Battery Replacement: Schritt 0, Bild 3 von 3
  • Once the battery is loose slowly lift it up so you can get to the terminals as seen in the next picture.
  • Desolder the battery's connection terminals from the motherboard.
  • If you do not know how to desolder look at this soldering and desoldering guide
  • Remove the battery by pulling it out of the device.
  • In order to avoid damage to the device, the battery must be physically removed from the device before proceeding with any further repairs . Leaving a battery close to a device being worked on can be extremely hazardous. Leads can bump into the motherboard or into each other by accident causing damage to the device.
Hier Übersetzung einfügen
