Zum Hauptinhalt wechseln
Kindle Paperwhite 3rd Generation Battery Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 2
Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: Schritt 0, Bild 1 von 3 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: Schritt 0, Bild 2 von 3 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: Schritt 0, Bild 3 von 3
Using caution
  • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
  • You want to make sure your separator goes through both sides of the bezel over top of the display.
  • The second photo is the layer you want your tool to pass through safely.
  • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
Hier Übersetzung einfügen
