Zum Hauptinhalt wechseln
1995-2001 Honda CRV Oil Change
Englisch
Koreanisch
Schritt 7
1995-2001 Honda CRV Oil Change: Schritt 0, Bild 1 von 3 1995-2001 Honda CRV Oil Change: Schritt 0, Bild 2 von 3 1995-2001 Honda CRV Oil Change: Schritt 0, Bild 3 von 3
  • To reach the oil filter, guide your hand around the back side of the drive axle and up toward the top of the engine.
  • Be careful if the engine has been running recently. The engine and exhaust components may be very hot.
  • Twist the oil filter counter-clockwise with your hand until it comes off the threads on the engine block.
  • If the filter is too tight to loosen by hand, use an oil filter wrench. A wrench that fits over the top of the oil filter is necessary, as there is very little space on the sides of the oil filter.
  • Lower the oil filter out of the engine bay with the threads facing up, then place it in the oil drain pan with the threads facing down.
  • Wipe off as much spilled oil as possible.
Hier Übersetzung einfügen
