Zum Hauptinhalt wechseln
iPod Touch 6th Generation Display Assembly Replacement
Englisch
Deutsch
Schritt 8
iPod Touch 6th Generation Display Assembly Replacement: Schritt 0, Bild 1 von 2 iPod Touch 6th Generation Display Assembly Replacement: Schritt 0, Bild 2 von 2
  • Insert the plastic opening tool between the frame and the rear case behind the first clip.
  • Rock the tool sideways, to spread the gap behind the clip and separate it from the rear case.
  • Initially this may not free the clip , but by repeating the procedure for each clip, it will begin to loosen the piece.
  • Repeat the procedure with the next two clips on that side
  • You may have to go back and forth between the clips to free all of them. Be patient, as the plastic frame is quite fragile.
Hier Übersetzung einfügen
