Zum Hauptinhalt wechseln
Canon EOS 5D Mark III Hauptplatine ersetzen
Englisch
Deutsch
Schritt 10
Canon EOS 5D Mark III Main Board Replacement, Remove internal connectors #1: Schritt 0, Bild 1 von 2 Canon EOS 5D Mark III Main Board Replacement, Remove internal connectors #1: Schritt 0, Bild 2 von 2
  • From this point on, be very careful. We will be removing or dislodging internal connectors that may be damaged if not careful and will impact the camera functions if not seated correctly when put back together.
  • First, label the two ribbon connectors with top and bottom and be sure which side attaches to the main board and which side attaches to the secondary board on the right. This is important because these connectors only go on one way and can not be switched.
  • Next, remove each connector like you did earlier with your nail or a small flat screwdriver.
  • Using that same small flat screwdriver, you will need to remove these two connectors from underneath the main pcb. Pry gently from each end of the connectors until they come loose.
  • Using some tweezers or a very small set of needle nose pliers, gently remove these two connectors from the top left of the main pcb. Be careful not to pull on the wires, ONLY the white connector ends to pull them out.
Hier Übersetzung einfügen
