Zum Hauptinhalt wechseln
Canon EOS 5D Mark III Hauptplatine ersetzen
Englisch
Deutsch
Schritt 11
Canon EOS 5D Mark III Main Board Replacement, Remove internal connectors #2: Schritt 0, Bild 1 von 3 Canon EOS 5D Mark III Main Board Replacement, Remove internal connectors #2: Schritt 0, Bild 2 von 3 Canon EOS 5D Mark III Main Board Replacement, Remove internal connectors #2: Schritt 0, Bild 3 von 3
  • These connectors have very small hinged flaps that must be lifted to let loose of the thin ribbon cables they're holding.
  • The flaps can be damaged very easily if not careful! Very gently use a dental pick or your nail to pry them upwards to release the tension on the cables underneath.
  • These ribbon cables may be gently pulled from the connectors with a small set of needle nose pliers. The one at the top of the board has a hole in the cable, so something very small like a tooth pick can fit in here to help pull the cable free.
  • This connector must be pried up with extreme caution. You absolutely can not pull on the wires leading into the connector as they are extremely delicate and will break easily. Using a small flat head screwdriver, pry up on either end very gently until the connector pops loose.
  • Underneath that connector is another that will need pried up. This one is another ribbon cable similar to the ones we've previously lifted with a small flat screwdriver.
  • Remove these three screws. They are all the same size.
  • Finally, remove this screw. It's a different size from the other three, so keep it separate.
Hier Übersetzung einfügen
