Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Schritt 12 übersetzen
Schritt 12
Use a thin pry tool or tweezers to carefully pry up and disconnect the two coaxial cable connectors from the logic board.
- | [* black] Use a thin pry tool or tweezers to carefully pry up and disconnect the two coaxial cable connectors from the logic board. |
+ | [* black] Use a thin pry tool or [product|IF145-020|tweezers] to carefully pry up and disconnect the two coaxial cable connectors from the logic board. |
[* icon_reminder] During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat of your spudger. The connector should snap into place. | |
+ | [* icon_note] The coaxial cable closest to the battery connector is responsible for the Wi-Fi Diversity Antenna. The other coaxial cable is for the secondary cell antenna. Make sure to reconnect them to the correct sockets. |
