Zum Hauptinhalt wechseln
iPhone 8 Plus Akku austauschen
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die die grundständige Anleitung beinhaltet.
Englisch
Deutsch
Schritt 5
iPhone 8 Plus Battery Replacement: Schritt 0, Bild 1 von 2 iPhone 8 Plus Battery Replacement: Schritt 0, Bild 2 von 2
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, remove it by adding a few drops of isopropyl alcohol (90% or greater) underneath the battery near the stuck strip(s). After about a minute, gently lift the battery.
  • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
  • If you choose to use pry tools to lift the battery out of the iPhone, use extreme caution or you may damage the ribbon cables or the wireless charging coil directly underneath the battery.
  • If the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery. This will help soften the adhesive.
  • Heat the iPhone until the rear case is slightly too hot to comfortably touch. Don't overheat the iPhone, or you may accidentally ignite the battery.
  • Alternatively, thread a strong piece of string (such as dental floss or a length of thin guitar string) underneath the battery.
  • Pull the string from side to side in a sawing motion all along the length of the battery to separate the adhesive. Do not deform or damage the battery.
  • To protect your fingers, wear gloves or wrap the string ends around a tool (such as the two screwdriver handles shown in the image).
Falls einer der Klebstreifen unter dem Akku gerissen ist und der Akku am Rückgehäuse festgeklebt bleibt, dann tröpfle etwas Isopropylakohol (mindestens 90%ig) nahe bei dem abgerissenen Streifen unter den Akku. Warte eine Minute, hebe dann den Akku heraus.
Versuche nicht, den Akku mit Gewalt herauszuhebeln. Tröpfle, wenn nötig, etwas mehr Alkohol hinein, um den Kleber weiter zu schwächen. Verbiege niemals den Akku mit dem Werkzeug und steche ihn nicht an.
Falls du Hebelwerkzeug benutzt, um den Akku aus den iPhone zu heben, sei extrem vorsichtig, damit du die Flachbandkabel oder die kabellose Ladespule direkt unter dem Akku nicht beschädigst.
Falls der Akku am Rückgehäuse festgeklebt bleibt, dann bereite einen iOpener vor oder benutze einen Fön, um das Rückgehäuse direkt hinter dem Akku zu erhitzen. Dadurch wird der Kleber aufgeweicht.
Erhitze das Rückgehäuse, bis es etwas zu heiß ist, um es noch bequem anfassen zu können. Überhitze das iPhone nicht, denn sonst könntest du versehentlich den Akku entzünden.
Du kannst auch einen starken Faden (wie zum Beispiel Zahnseide oder eine dünne Gitarrensaite) unter dem Akku durchziehen.
Ziehe den Faden über die ganze Länge des Akkus wie eine Säge hin und her, um den Kleber zu lösen. Verforme oder beschädige auf keinen Fall den Akku.
Schütze deine Finger und trage Handschuhe oder schlinge die Enden um ein Werkzeug (z.B. Schraubendrehergriffe, so wie im Bild gezeigt).
