Einleitung
If you are experiencing an oil leak with a lot of debris around the oil cover, noticeable aroma of burning oil and or oil in the spark plug housing, then it may be time to replace the valve cover gasket.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the Replacement yourself.
Torque specs:
- 8.7 ft. lbs - Head cover bolts
- 8.7 ft. lbs - Power steering pressure hose
- 8.7 ft. lbs - Side bracket bolts
- 8.7 ft. lbs - Plastic head cover bolts
Safety
If this is your first time working on a vehicle read our safety tips before proceeding.
Was du brauchst
Videoanleitungen
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
