Zum Hauptinhalt wechseln
ANKER SoundCore Battery/Battery Wire Replacement
Was du brauchst
  1. ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: Schritt 1, Bild 1 von 3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: Schritt 1, Bild 2 von 3 ANKER SoundCore Battery/Battery Wire Replacement, Battery/Battery Wire: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Battery/Battery Wire Replacement: Schritt 2, Bild 1 von 1
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
    • Remove the speaker mount gently.
  3. ANKER SoundCore Battery/Battery Wire Replacement: Schritt 3, Bild 1 von 3 ANKER SoundCore Battery/Battery Wire Replacement: Schritt 3, Bild 2 von 3 ANKER SoundCore Battery/Battery Wire Replacement: Schritt 3, Bild 3 von 3
    • Remove the two 8mm Phillips #0 screws from the circuit board.
    • Remove the circuit board from its mount.
  4. ANKER SoundCore Battery/Battery Wire Replacement: Schritt 4, Bild 1 von 3 ANKER SoundCore Battery/Battery Wire Replacement: Schritt 4, Bild 2 von 3 ANKER SoundCore Battery/Battery Wire Replacement: Schritt 4, Bild 3 von 3
    • Find the battery below the circuit board.
    • It is covered by fuzz that is the same color as the black casing, so it may be hard to see.
    • Pry the battery off using the iFixit opening tool.
    • Remove the battery from its holder.
  5. ANKER SoundCore Battery/Battery Wire Replacement: Schritt 5, Bild 1 von 1
    • Desolder the battery wires.
    • Remove the battery and battery wire from the device.
    • For more information on soldering and desoldering connections, follow this guide.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S22-G1, Regan Winter 2020 Mitglied von Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 Mitglieder
6 Anleitungen geschrieben
4 Kommentare
If a bt speaker battery died,the unit can't power up by cable?
limz555 - Antwort
Nice guide… showed how to get the grill off… Unfortunately, my circuit board is epoxied in place.
Battery tests ok, but unit won’t turn on. Its going into the bag with other non-working electronics unless you have any ideas. The little speakers look very nice…
manfred.humphries - Antwort
My Anker works as long as it is plugged in (usb). As soon as the lead is removed, it dies.
David Goodacre - Antwort
Where do I get the new battery in India?
Raghubir Roy L - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 21
Letzte 7 Tage: 116
Letzte 30 Tage: 526
Insgesamt: 17,414
