Zum Hauptinhalt wechseln
ANKER SoundCore Charging Port Replacement
Was du brauchst
  1. ANKER SoundCore Charging Port Replacement, Charging Port: Schritt 1, Bild 1 von 3 ANKER SoundCore Charging Port Replacement, Charging Port: Schritt 1, Bild 2 von 3 ANKER SoundCore Charging Port Replacement, Charging Port: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to pry off the screen.
    • Remove the screen from the device.
  2. ANKER SoundCore Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the eight 10 mm Phillips #0 screws from the speaker mount.
  3. ANKER SoundCore Charging Port Replacement: Schritt 3, Bild 1 von 2 ANKER SoundCore Charging Port Replacement: Schritt 3, Bild 2 von 2
    • Use the metal spludger to pry off speaker mount.
  4. ANKER SoundCore Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 8mm Phillips #0 screws from the circuit board.
  5. ANKER SoundCore Charging Port Replacement: Schritt 5, Bild 1 von 2 ANKER SoundCore Charging Port Replacement: Schritt 5, Bild 2 von 2
    • Carefully remove the circuit board from the speaker body.
  6. ANKER SoundCore Charging Port Replacement: Schritt 6, Bild 1 von 2 ANKER SoundCore Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Use the iFixit Opening Pick to pry off the charging port cover.
    • Remove the charging port cover.
  7. ANKER SoundCore Charging Port Replacement: Schritt 7, Bild 1 von 2 ANKER SoundCore Charging Port Replacement: Schritt 7, Bild 2 von 2
    • Desolder the charging port from the circuit board.
    • Solder a new charging port in place of the old one.
    • For help soldering and desoldering, follow this guide.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Briana Kuo
311 Reputation
1 Anleitung geschrieben
Cal Poly, Team S22-G1, Regan Winter 2020 Mitglied von Cal Poly, Team S22-G1, Regan Winter 2020
CPSU-REGAN-W20S22G1
5 Mitglieder
6 Anleitungen geschrieben
4 Kommentare
Where can I find a replacement port that is compatible?
tommy2197 - Antwort
Mike - Antwort
The Charging port is an USB Mirco Port. To find right part search for JBL FLIP 3 on ebay or other platforms. It is the same part as used for the Anker SoundCore.
Agi -
Hi I have a Anker soundcore motion plus, the charging port is loose and not charging, it's a usb c, where can I buy that replacement part
.thanks
Justin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 36
Letzte 30 Tage: 154
Insgesamt: 10,252
