Zum Hauptinhalt wechseln
ASUS Q405U Battery Replacement
Was du brauchst
  1. ASUS Q405U Battery Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
  2. ASUS Q405U Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
  3. ASUS Q405U Battery Replacement: Schritt 3, Bild 1 von 3 ASUS Q405U Battery Replacement: Schritt 3, Bild 2 von 3 ASUS Q405U Battery Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
  4. ASUS Q405U Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
  5. ASUS Q405U Battery Replacement: Schritt 5, Bild 1 von 1
    • Once all screws are removed, lift the battery out from the base of the computer.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 2-8, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G8
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 49
Insgesamt: 1,580
