Zum Hauptinhalt wechseln
ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement
Was du brauchst
  1. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Bottom Cover: Schritt 1, Bild 1 von 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 2, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the Battery: Schritt 3, Bild 1 von 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Heat Shield: Schritt 4, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Heat Shield: Schritt 4, Bild 2 von 2
    • Remove the black shield covering the display connector and the heat sink.
    • You may need to use double-sided adhesive tape to resecure the shield.
  5. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Display Assembly: Schritt 5, Bild 1 von 1
    • Remove the black tape securing the keyboard ribbon cable to the display connector.
    • Fold the ribbon cable the opposite way, resecuring it to the hard drive to keep it out of the way.
  6. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 6, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 6, Bild 2 von 2
    • Peel off the clear tape from the motherboard display connector.
  7. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 7, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 7, Bild 2 von 2
    • Position spudgers on the white tabs on either side of the connector and push evenly to unplug the display.
  8. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 8, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 8, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 8, Bild 3 von 3
    • Peel off the three pieces of black tape securing the display cable to the motherboard.
    • Deroute the cable from the channel it sits in.
    • Move the cable to the side, out of the way.
  9. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 9, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 9, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 9, Bild 3 von 3
    • Use a spudger to release the cables from the wifi card.
  10. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 10, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 10, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 10, Bild 3 von 3
    • Lift the tapes securing the wires to the motherboard.
    • Move the wires to the side out of the way.
  11. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the Hinges: Schritt 11, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the Hinges: Schritt 11, Bild 2 von 2
    • Remove the two screws securing the hinge on the left.
    • Pry the hinge up by hand to a 90 degree angle.
  12. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 12, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 12, Bild 2 von 2
    • Remove the two screws securing the hinge on the right.
  13. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display: Schritt 13, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display: Schritt 13, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display: Schritt 13, Bild 3 von 3
    • Lift the base of the laptop from the front.
    • Raise it to a 90 degree angle.
    • Slide it forward slightly to clear the hinges.
    • The display is now free.
  14. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display Retaining Screws: Schritt 14, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display Retaining Screws: Schritt 14, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Display Retaining Screws: Schritt 14, Bild 3 von 3
    • There are two black square plastic tabs covering the retaining screws. The tabs are fixed in place with light adhesive.
    • Using a thin blade, pry off the tabs covering the screws.
  15. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 15, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 15, Bild 2 von 2
    • With a Phillips #0 screwdriver, remove the two 3.8 mm screws holding the bezel in place.
  16. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Hinge Cover: Schritt 16, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Hinge Cover: Schritt 16, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Hinge Cover: Schritt 16, Bild 3 von 3
    • Grasp the hinge cover and slide it to the right. It will only move about 3mm (1/8 inch).
  17. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 17, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 17, Bild 2 von 2
    • Tilt the hinge cover toward you and pull up to remove it.
    • It may catch on the parts it's covering as you remove it. If that happens, just wiggle it around until it comes free.
    • No force should be needed to remove it. You do not have to pry on it to take it out.
  18. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Release the Display Panel: Schritt 18, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Release the Display Panel: Schritt 18, Bild 2 von 2
    • Slide the screen down to release the catches holding it in place.
    • It will only move about 3mm (1/8 inch) and will stop when it has moved sufficiently.
  19. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 19, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 19, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 19, Bild 3 von 3
    • Lift up on the now-exposed bottom edge of the screen. Go around the edges, lifting it away from the housing. If it is still caught anywhere, remember to slide it down to free it.
    • Again, no force is needed. You do not have to pry on it to take it out. Doing so will damage the housing and/or the bezel.
    • Slide the screen out from under the hinges and remove it.
  20. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the LCD Cable: Schritt 20, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Disconnect the LCD Cable: Schritt 20, Bild 2 von 2
    • Flip the touch screen assembly over and peel the clear tape covering the LCD connector off the LCD panel.
  21. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 21, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 21, Bild 2 von 2
    • Using a spudger, slide the connector out in the direction of the bottom of the screen.
  22. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Touchscreen Controller Board: Schritt 22, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Touchscreen Controller Board: Schritt 22, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Touchscreen Controller Board: Schritt 22, Bild 3 von 3
    • The next few steps are easier if you rotate the display so the top of the screen is facing you.
    • Peel off the tape providing a ground point to the LCD frame.
    • Use the flat end of a spudger to flip up the latch on the right connector.
  23. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 23, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 23, Bild 2 von 2
    • Use the flat end of a spudger to flip up the latch on the left connector.
  24. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 24, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 24, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use fine tip tweezers to slide the right ribbon cable out of the connector.
  25. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 25, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 25, Bild 2 von 2
    • Use fine tip tweezers to slide the left ribbon cable out of the connector.
  26. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 26, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 26, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 26, Bild 3 von 3
    • The touchscreen board is secured to the bezel with two latches on the far side and a plastic hook on the near side.
    • Use a spudger to open the right latch while gently prying up with an opening tool or a fingernail.
    • Use a spudger to open the left latch while gently prying up with an opening tool or a fingernail.
  27. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 27, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 27, Bild 2 von 2
    • Rotate the board toward you while sliding it forward slightly to free it from the bottom hook.
    • Lift the board away from the bezel and move it aside.
  28. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Microphone Board: Schritt 28, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Microphone Board: Schritt 28, Bild 2 von 2
    • The microphone daughterboard is held in place by being pressed down onto a plastic pin.
    • Pry it up off the retaining pin with a plastic spudger.
  29. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Camera Board: Schritt 29, Bild 1 von 2 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Dismount the Camera Board: Schritt 29, Bild 2 von 2
    • The camera daughterboard is held in place with two latches along the top of the board and two hooks on the bottom.
    • It is seated on two plastic guide pins as well.
    • Be sure the board is fully seated on the guide pins when reassembling.
  30. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 30, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 30, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 30, Bild 3 von 3
    • Slide a thin pry tool between the top of the camera board and the lip of the bezel.
    • Gently pry up on the board to free it from the latches and the guide pins it sits on.
    • Lift it up and away from the bezel and set it to the side.
  31. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Wiring Harness: Schritt 31, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Wiring Harness: Schritt 31, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement, Remove the Wiring Harness: Schritt 31, Bild 3 von 3
    • Carefully remove the five pieces of conductive tape securing the cables to the LCD frame.
  32. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 32, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 32, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 32, Bild 3 von 3
    • Deroute the wiring to the daughterboards from the front bezel.
  33. ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 33, Bild 1 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 33, Bild 2 von 3 ASUS VivoBook S400C LCD / Touch Screen Assembly Replacement: Schritt 33, Bild 3 von 3
    • Deroute the LCD cable from the display.
    • The LCD / digitizer assembly is now free.
Abschluss
Jerry Wheeler
61.046 Reputation
71 Anleitungen geschrieben
Oregonians Mitglied von Oregonians
Community
8 Mitglieder
183 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 363
