Einleitung
A common issue laptop owners face is battery failure. As batteries age, they swell and begin to not hold their charge for as long. Whether your battery appears to be intact, or it has swollen like a balloon, a defective laptop battery is an essential fix. These listed steps are specific to the Acer Aspire 3, however they generally apply to most other laptop devices as well.
Was du brauchst
Close the laptop and flip it over.
Remove the eleven 6.5 mm Phillips screws from the lower case.
Insert an opening pick between the lower case and chassis.
Pry around the entire perimeter until the lower case releases.
Remove the lower case.
Grip the white battery connector and pull it directly out of its socket.
For optimal performance, calibrate your newly installed battery after completing this guide.
