Zum Hauptinhalt wechseln
Acer Chromebook CB3-532-C47C Motherboard Replacement
Was du brauchst
  1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Motherboard Replacement: Schritt 2, Bild 1 von 2 Acer Chromebook CB3-532-C47C Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove the battery cable: Schritt 3, Bild 1 von 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: Schritt 4, Bild 1 von 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: Schritt 4, Bild 2 von 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: Schritt 5, Bild 1 von 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: Schritt 5, Bild 2 von 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: Schritt 5, Bild 3 von 3
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
  6. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: Schritt 6, Bild 1 von 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: Schritt 6, Bild 2 von 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  7. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: Schritt 7, Bild 1 von 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: Schritt 7, Bild 2 von 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: Schritt 7, Bild 3 von 3
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  8. Acer Chromebook CB3-532-C47C Motherboard Replacement: Schritt 8, Bild 1 von 3 Acer Chromebook CB3-532-C47C Motherboard Replacement: Schritt 8, Bild 2 von 3 Acer Chromebook CB3-532-C47C Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  9. Acer Chromebook CB3-532-C47C Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  10. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove Motherboard: Schritt 10, Bild 1 von 1
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sadie Brown
967 Reputation
7 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Sinclaire Fall 2021 Mitglied von UMass Dartmouth, Team 3-2, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G2
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 23
Insgesamt: 601
