Zum Hauptinhalt wechseln
Acer Predator Helios 300 (2020) Battery Replacement
Was du brauchst
  1. Acer Predator Helios 300 (2020) Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Predator Helios 300 (2020) Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn off the laptop by holding the power button for 7 seconds.
  2. Acer Predator Helios 300 (2020) Battery Replacement: Schritt 2, Bild 1 von 2 Acer Predator Helios 300 (2020) Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the eleven black 7.0 mm screws using a Phillips #00 screwdriver.
  3. Acer Predator Helios 300 (2020) Battery Replacement: Schritt 3, Bild 1 von 2 Acer Predator Helios 300 (2020) Battery Replacement: Schritt 3, Bild 2 von 2
    • Put your hands on the white part of the chassis and pull up until you hear a snap.
    • Lift up the back panel and remove it from the device.
  4. Acer Predator Helios 300 (2020) Battery Replacement: Schritt 4, Bild 1 von 3 Acer Predator Helios 300 (2020) Battery Replacement: Schritt 4, Bild 2 von 3 Acer Predator Helios 300 (2020) Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 4.0 mm golden screws using the Phillips #00 screwdriver.
  5. Acer Predator Helios 300 (2020) Battery Replacement: Schritt 5, Bild 1 von 3 Acer Predator Helios 300 (2020) Battery Replacement: Schritt 5, Bild 2 von 3 Acer Predator Helios 300 (2020) Battery Replacement: Schritt 5, Bild 3 von 3
    • Disconnect the battery connector.
  6. Acer Predator Helios 300 (2020) Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery from the laptop.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Steven Yuen
349 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 11-27, Grodsky Fall 2021 Mitglied von CSU Los Angeles, Team 11-27, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G27
1 Mitglied
Ein Kommentar
You're awesome, full stop. Thanks for this ridiculously easy to follow guide. Publishing guides should be your job.
Jeff Noble - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 79
Letzte 30 Tage: 362
Insgesamt: 11,594
