Zum Hauptinhalt wechseln
Alienware M17-R1 Screen Lock Assembly Replacement
Was du brauchst
  1. Alienware M17-R1 Screen Lock Assembly Replacement, Screen Lock Assembly: Schritt 1, Bild 1 von 1
    • Open the screen until it is flat.
    • Ensure that the surface you are working on can support both the screen and the base of the laptop.
    Frag FixBot
    Kommentar hinzufügen
  2. Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 2, Bild 1 von 2 Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 2, Bild 2 von 2
    • Remove the eight 7 mm screws around the edge of the screen using a Phillips #1 screwdriver.
    • Support the screen from the bottom to make it easier to remove the screws.
    Frag FixBot
  3. Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 3, Bild 1 von 2 Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 3, Bild 2 von 2
    • Insert the plastic opening tool and gently slide it around the edge of the screen to lift the face of the screen away from its base.
    • Be careful not to break the face of the screen when lifting it.
    Frag FixBot
  4. Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 4, Bild 1 von 3 Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 4, Bild 2 von 3 Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 4, Bild 3 von 3
    • Remove the two 3 mm Phillips #1 screws using a Phillips #1 screwdriver.
    • Pull the assembly grip away to remove it.
    • Remove the two 5 mm screws using a Phillips #1 screwdriver.
    Frag FixBot
  5. Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 5, Bild 1 von 2 Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 5, Bild 2 von 2
    • Push in the assembly towards the spring.
    • Gently lift the slider from the side opposite to the spring and pull the slider away from the spring.
    • The spring is loosely secured to the slider and may fall off and become lost when removing the slider.
    Frag FixBot
  6. Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 6, Bild 1 von 2 Alienware M17-R1 Screen Lock Assembly Replacement: Schritt 6, Bild 2 von 2
    • If the spring is defective, slide it off the end of the assembly and replace it.
    Frag FixBot
Abschluss
Sam Houston State, Team S15-G2, Blackburne Fall 2018 Mitglied von Sam Houston State, Team S15-G2, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 726
