Zum Hauptinhalt wechseln
Alienware M17x RAM Replacement
Was du brauchst
    1. Alienware M17x RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Alienware M17x RAM Replacement, Battery: Schritt 1, Bild 2 von 2
      • Turn off your laptop before starting.
      • Flip the laptop over so the model stickers face the ceiling.
      Frag FixBot
      Kommentar hinzufügen
    2. Alienware M17x RAM Replacement: Schritt 2, Bild 1 von 1
      • Remove the two 3.5 mm Phillips #0 screws holding the cover in place.
      • Slide cover forward then carefully lift up.
      Frag FixBot
    3. Alienware M17x RAM Replacement: Schritt 3, Bild 1 von 1
      • Remove the two 5.5 mm Phillips #0 screws holding the battery in place.
      Frag FixBot
    4. Alienware M17x RAM Replacement: Schritt 4, Bild 1 von 2 Alienware M17x RAM Replacement: Schritt 4, Bild 2 von 2
      • Carefully use the Plastic Opening Tool to unplug the battery.
      • Lift the battery up and out to remove.
      Frag FixBot
    1. Alienware M17x RAM Replacement, RAM: Schritt 5, Bild 1 von 2 Alienware M17x RAM Replacement, RAM: Schritt 5, Bild 2 von 2
      • With the laptop flipped over, cover removed, and battery removed; continue by locating your RAM cards.
      Frag FixBot
    2. Alienware M17x RAM Replacement: Schritt 6, Bild 1 von 2 Alienware M17x RAM Replacement: Schritt 6, Bild 2 von 2
      • Remove the top RAM card by pressing the tabs to the sides using the Plastic Opening Tool.
      • Once the top card has popped up, carefully remove it by holding the sides and sliding it out.
      Frag FixBot
    3. Alienware M17x RAM Replacement: Schritt 7, Bild 1 von 1
      • Remove the bottom RAM card in a similar manner.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
The only problem is that this laptop has 4 slots of ram there are 2 more under the keyboard that must also be accessed to update. If anyone wants to know how I know it’s because I have this laptop and I have seen where the next lot of ram is located
Neil Radtke - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 32
Insgesamt: 868
