Zum Hauptinhalt wechseln
Alienware X51 R1/R2/R3 RAM Replacement
Was du brauchst
  1. Alienware X51 R1/R2/R3 RAM Replacement, Remove Panel Screw: Schritt 1, Bild 1 von 1
    • First, turn the computer so you can see the rear panel. Remove the small screw to the right (or above, if the system is on its side) of the audio jacks.
    • Once the screw is removed, use both hands to push the side panel down and towards the front of the case.
    Frag FixBot
    Kommentar hinzufügen
  2. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect LED Control Cable: Schritt 2, Bild 1 von 1
    • Lift the side panel off, and gently flip it over the top of the system, being careful not to break the LED control cable. Unplug its connector and set the case panel to the side.
    Frag FixBot
  3. Alienware X51 R1/R2/R3 RAM Replacement, Remove Fan Screws: Schritt 3, Bild 1 von 1
    • Next, remove the screws securing the plastic air re-director (not shown in picture) to the fan, and gently lift it out of the case. Set aside and move to the next step.
    Frag FixBot
  4. Alienware X51 R1/R2/R3 RAM Replacement, Disconnect/Remove the DVD Drive: Schritt 4, Bild 1 von 1
    • Unplug the SATA cable at the base of the DVD drive circled in blue. This cable will have a lot of tension on it, but do not worry. Just be careful not to yank on it too much.
    • You will then unscrew the screw securing the DVD drive to the case (circled in red). Once the screw is removed, remove the DVD drive and set to the side.
    Frag FixBot
  5. Alienware X51 R1/R2/R3 RAM Replacement: Schritt 5, Bild 1 von 1
    • Now, push the white latch (circled in red) DOWN and pull the ram card straight up to a ~45 degree angle. Pull up and out, towards the latch side, and set aside.
    Frag FixBot
  6. Alienware X51 R1/R2/R3 RAM Replacement, Insert New Ram Card: Schritt 6, Bild 1 von 1
    • You will insert the new DIMM. Push the side opposite to the latch in first, being sure that the notch in the connector matches the location on the ram DIMM.
    • Insert at a ~45 degree angle and push straight down into the socket, being sure that the latch clicks.
    • DO NOT FORCE THE DIMM IN. Rotate the card and try again if the card will not go into the port.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Pasco Hernando, Team 5-6, Prince Winter 2016 Mitglied von Pasco Hernando, Team 5-6, Prince Winter 2016
PHSC-PRINCE-W16S5G6
1 Mitglied
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 51
Insgesamt: 7,074
