Zum Hauptinhalt wechseln
Alienware X51 RAM Replacement
Was du brauchst
  1. Alienware X51 RAM Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Place the PC so the name "Alienware" is on top and facing you.
    • Slide the front panel towards you and lift up.
    Frag FixBot
    Kommentar hinzufügen
  2. Alienware X51 RAM Replacement: Schritt 2, Bild 1 von 1
    • Fully disconnect the panel by unplugging the lighting cord going into the PC's internal system.
    • Remove the front panel from the rest of the device.
    Frag FixBot
  3. Alienware X51 RAM Replacement, Fan: Schritt 3, Bild 1 von 2 Alienware X51 RAM Replacement, Fan: Schritt 3, Bild 2 von 2
    • Remove the two 2.0 mm screws holding the fan protector in place using a Phillips #1 screwdriver.
    • Remove the protector holding the fan in.
    Frag FixBot
  4. Alienware X51 RAM Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the Molex KK connector from the fan.
    Frag FixBot
  5. Alienware X51 RAM Replacement: Schritt 5, Bild 1 von 3 Alienware X51 RAM Replacement: Schritt 5, Bild 2 von 3 Alienware X51 RAM Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #1 screwdriver to loosen the four spring screws around the fan until you hear a click.
    • Gently pull back the clips and remove the fan by pulling it out.
    Frag FixBot
  6. Alienware X51 RAM Replacement, Disc Drive: Schritt 6, Bild 1 von 2 Alienware X51 RAM Replacement, Disc Drive: Schritt 6, Bild 2 von 2
    • Disconnect the optical-drive data and power cable.
    Frag FixBot
  7. Alienware X51 RAM Replacement: Schritt 7, Bild 1 von 1
    • Remove the one 1.0 mm screw using a Phillips #1 screwdriver.
    • Remove the disc drive from the PC.
    Frag FixBot
  8. Alienware X51 RAM Replacement, RAM: Schritt 8, Bild 1 von 3 Alienware X51 RAM Replacement, RAM: Schritt 8, Bild 2 von 3 Alienware X51 RAM Replacement, RAM: Schritt 8, Bild 3 von 3
    • Pull apart the clips that hold the RAM sticks in place.
    • Remove the RAM sticks.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 31
Insgesamt: 555
