Zum Hauptinhalt wechseln
Altec Lansing BoomJacket Battery Replacement
Was du brauchst
    1. Altec Lansing BoomJacket Battery  Replacement, Case Removal: Schritt 1, Bild 1 von 1
      • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
      Frag FixBot
      Kommentar hinzufügen
    2. Altec Lansing BoomJacket Battery  Replacement: Schritt 2, Bild 1 von 1
      • Remove the outer black rubber housing of the speaker.
      Frag FixBot
    3. Altec Lansing BoomJacket Battery  Replacement: Schritt 3, Bild 1 von 1
      • Remove the inner blue rubber housing from the speaker.
      Frag FixBot
    4. Altec Lansing BoomJacket Battery  Replacement: Schritt 4, Bild 1 von 1
      • Pull out the two black wire meshes using a metal spudger.
      • Be careful not to damage the metal casing.
      Frag FixBot
    5. Altec Lansing BoomJacket Battery  Replacement: Schritt 5, Bild 1 von 2 Altec Lansing BoomJacket Battery  Replacement: Schritt 5, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
      Frag FixBot
    6. Altec Lansing BoomJacket Battery  Replacement: Schritt 6, Bild 1 von 1
      • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
      Frag FixBot
    7. Altec Lansing BoomJacket Battery  Replacement: Schritt 7, Bild 1 von 1
      • Pull the case apart and you will be able to see all the components inside the speaker.
      Frag FixBot
    1. Altec Lansing BoomJacket Battery  Replacement, Battery: Schritt 8, Bild 1 von 1
      • The battery will be sitting right behind the speakers when the case is open.
      Frag FixBot
    2. Altec Lansing BoomJacket Battery  Replacement: Schritt 9, Bild 1 von 1
      • Unplug and disconnect the battery from the motherboard.
      Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
6 Kommentare zur Anleitung
Where can you buy a replacement battery?
Darrell riley - Antwort Teilen
Where can you buy the battery please?
Juan Roa - Antwort Teilen
Where can I find ghe batteries? What type of battery ?
Violet Roach - Antwort Teilen
where ca i buy a replacement battery
Shelley Franck - Antwort Teilen
This tutorial is incomplete.
Ivan Rodriguez - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 58
Insgesamt: 15,961
