Zum Hauptinhalt wechseln
Altec Lansing BoomJacket Power Button Replacement
Was du brauchst
    1. Altec Lansing BoomJacket Power Button Replacement, Case Removal: Schritt 1, Bild 1 von 1
      • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
      Frag FixBot
      Kommentar hinzufügen
    2. Altec Lansing BoomJacket Power Button Replacement: Schritt 2, Bild 1 von 1
      • Remove the outer black rubber housing of the speaker.
      Frag FixBot
    3. Altec Lansing BoomJacket Power Button Replacement: Schritt 3, Bild 1 von 1
      • Remove the inner blue rubber housing from the speaker.
      Frag FixBot
    4. Altec Lansing BoomJacket Power Button Replacement: Schritt 4, Bild 1 von 1
      • Pull out the two black wire meshes using a metal spudger.
      • Be careful not to damage the metal casing.
      Frag FixBot
    5. Altec Lansing BoomJacket Power Button Replacement: Schritt 5, Bild 1 von 2 Altec Lansing BoomJacket Power Button Replacement: Schritt 5, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
      Frag FixBot
    6. Altec Lansing BoomJacket Power Button Replacement: Schritt 6, Bild 1 von 1
      • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
      Frag FixBot
    7. Altec Lansing BoomJacket Power Button Replacement: Schritt 7, Bild 1 von 1
      • Pull the case apart and you will be able to see all the components inside the speaker.
      Frag FixBot
    1. Altec Lansing BoomJacket Power Button Replacement, Power Button: Schritt 8, Bild 1 von 1
      • The battery will be sitting right behind the speakers when the case is open.
      Frag FixBot
    2. Altec Lansing BoomJacket Power Button Replacement: Schritt 9, Bild 1 von 2 Altec Lansing BoomJacket Power Button Replacement: Schritt 9, Bild 2 von 2
      • Unplug and disconnect the battery from the motherboard.
      Frag FixBot
    3. Altec Lansing BoomJacket Power Button Replacement: Schritt 10, Bild 1 von 1
      • Using a size PH1 screwdriver, remove the two screws.
      Frag FixBot
    4. Altec Lansing BoomJacket Power Button Replacement: Schritt 11, Bild 1 von 2 Altec Lansing BoomJacket Power Button Replacement: Schritt 11, Bild 2 von 2
      • You will now see the motherboard for the power button.
      • Remove the 2 screws holding the motherboard into place.
      Frag FixBot
    5. Altec Lansing BoomJacket Power Button Replacement: Schritt 12, Bild 1 von 1
      • Pick up the motherboard and take it out of the slot.
      Frag FixBot
    6. Altec Lansing BoomJacket Power Button Replacement: Schritt 13, Bild 1 von 1
      • Disconnect the power button motherboard from the speaker motherboard.
      Frag FixBot
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Current speaker won’t turn on even though charging light looks all good so came across these instructions.
Thinking it’s the power button on my speaker that’s the issue.
Assuming these instructions are assuming you are replacing the power button motherboard? Where could I source one?
Cat Moure - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 21,358
