Zum Hauptinhalt wechseln
Amazon Echo Studio Tweeter Replacement
Was du brauchst
    1. Amazon Echo Studio Tweeter Replacement, Power Supply Board: Schritt 1, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement, Power Supply Board: Schritt 1, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement, Power Supply Board: Schritt 1, Bild 3 von 3
      • Flip the device upside down.
      • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
      Frag FixBot
      Kommentar hinzufügen
    2. Amazon Echo Studio Tweeter Replacement: Schritt 2, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 2, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 2, Bild 3 von 3
      • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
      • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
      • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
      Frag FixBot
    3. Amazon Echo Studio Tweeter Replacement: Schritt 3, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 3, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 3, Bild 3 von 3
      • Before fully removing the base, remove the three attached connectors.
      Frag FixBot
    4. Amazon Echo Studio Tweeter Replacement: Schritt 4, Bild 1 von 2 Amazon Echo Studio Tweeter Replacement: Schritt 4, Bild 2 von 2
      • Now unscrew the the single 10 mm Phillips screw.
      • Remove the power supply board.
      Frag FixBot
    1. Amazon Echo Studio Tweeter Replacement, Subwoofer: Schritt 5, Bild 1 von 1
      • Remove the two screws located across from each other on the outside of the plastic ring shown.
      • Remove the plastic outer ring that hugs the inside of the edges of the device.
      • This may require you to use a soft prying tool to separate it from the outer shell.
      Frag FixBot
    2. Amazon Echo Studio Tweeter Replacement: Schritt 6, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 6, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 6, Bild 3 von 3
      • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
      • Once the screws are removed, take the power supply's baseplate out of the unit.
      • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
      Frag FixBot
    3. Amazon Echo Studio Tweeter Replacement: Schritt 7, Bild 1 von 2 Amazon Echo Studio Tweeter Replacement: Schritt 7, Bild 2 von 2
      • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
      • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
      • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
      • Your subwoofer is now disconnected and ready to be replaced.
      Frag FixBot
    1. Amazon Echo Studio Tweeter Replacement, Motherboard: Schritt 8, Bild 1 von 2 Amazon Echo Studio Tweeter Replacement, Motherboard: Schritt 8, Bild 2 von 2
      • Remove the thirteen 9 mm Phillips #00 screws.
      • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
      Frag FixBot
    2. Amazon Echo Studio Tweeter Replacement: Schritt 9, Bild 1 von 1
      • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
      • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
      Frag FixBot
    3. Amazon Echo Studio Tweeter Replacement: Schritt 10, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 10, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 10, Bild 3 von 3
      • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
      Frag FixBot
    4. Amazon Echo Studio Tweeter Replacement: Schritt 11, Bild 1 von 1
      • Remove the motherboard from the device by pulling it out.
      • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
      Frag FixBot
    1. Amazon Echo Studio Tweeter Replacement, Light Board: Schritt 12, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement, Light Board: Schritt 12, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement, Light Board: Schritt 12, Bild 3 von 3
      • First, locate the six 10 mm screws at the top of the inside of the shell and unscrew them with a T10 Torx screwdriver.
      • After removing the six screws from the inside, lift the top speaker cover.
      Frag FixBot
    2. Amazon Echo Studio Tweeter Replacement: Schritt 13, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 13, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 13, Bild 3 von 3
      • Lift the top plastic cover that has the buttons.
      • If you feel a lot of resistance while removing this piece, check if you removed every screw from the inside or you risk breaking this part.
      Frag FixBot
    3. Amazon Echo Studio Tweeter Replacement: Schritt 14, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 14, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 14, Bild 3 von 3
      • After the screws are removed, carefully lift the lightboard and disconnect the ribbon.
      • Make sure you do not forget to detach the ribbon from the shell, or you risk breaking it.
      Frag FixBot
    1. Amazon Echo Studio Tweeter Replacement, Tweeter: Schritt 15, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement, Tweeter: Schritt 15, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement, Tweeter: Schritt 15, Bild 3 von 3
      • Remove the four 3.27 mm screws with T15 Torx driver.
      • After removing the screws, push/pull the inner shell out of the outer shell.
      • You might need someone's help to remove the inside shell, because it is very tight inside the outer shell.
      Frag FixBot
    2. Amazon Echo Studio Tweeter Replacement: Schritt 16, Bild 1 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 16, Bild 2 von 3 Amazon Echo Studio Tweeter Replacement: Schritt 16, Bild 3 von 3
      • Remove the wire from its slot inside the shell so the tweeter can be removed.
      • Unscrew the two 3.2 mm screws holding the tweeter in place with a T15 Torx screwdriver.
      • Pull the tweeter out.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UMass Dartmouth, Team 2-6, Petersen Fall 2022 Mitglied von UMass Dartmouth, Team 2-6, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G6
4 Mitglieder
31 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 29
Insgesamt: 607
