Zum Hauptinhalt wechseln
Astak Mole Motor Replacement
Was du brauchst
    1. Astak Mole  Motor Replacement, Lower Case: Schritt 1, Bild 1 von 1
      • Remove the four bottom tabs in order to access the bottom screws.
      Frag FixBot
      Kommentar hinzufügen
    2. Astak Mole  Motor Replacement: Schritt 2, Bild 1 von 1
      • Remove all four 14 mm Phillips #1 screws.
      Frag FixBot
    3. Astak Mole  Motor Replacement: Schritt 3, Bild 1 von 1
      • Remove the SD card.
      Frag FixBot
    4. Astak Mole  Motor Replacement: Schritt 4, Bild 1 von 1
      • Pry up the motherboard on the four points using a spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Frag FixBot
    5. Astak Mole  Motor Replacement: Schritt 5, Bild 1 von 1
      • Gently pull back the motherboard to expose many of the component's wired connections.
      Frag FixBot
    1. Astak Mole  Motor Replacement, Electric Motor Assembly: Schritt 6, Bild 1 von 1
      • Unscrew both screws using the Phillips head (PH1) screw bit and set aside for reassembly
      • Screw Measurements: Length: 7.1mm
      • The motor should be free of its housing and only be attached to the motherboard by its wires.
      Frag FixBot
    2. Astak Mole  Motor Replacement: Schritt 7, Bild 1 von 1
      • Sever motor connection to motherboard and remove wire carefully.
      • Optional: Use electrical adhesive to prevent dislodging of new wired connection.
      Frag FixBot
Abschluss
USF Tampa, Team 2-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Mitglieder
18 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 29
Insgesamt: 761
