Zum Hauptinhalt wechseln
Astak Mole Microphone Replacement
Was du brauchst
  1. Astak Mole Microphone  Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove the four bottom tabs in order to access the bottom screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Astak Mole Microphone  Replacement: Schritt 2, Bild 1 von 1
    • Remove all four 14 mm Phillips #1 screws.
    Frag FixBot
  3. Astak Mole Microphone  Replacement: Schritt 3, Bild 1 von 1
    • Remove the SD card.
    Frag FixBot
  4. Astak Mole Microphone  Replacement: Schritt 4, Bild 1 von 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
    Frag FixBot
  5. Astak Mole Microphone  Replacement: Schritt 5, Bild 1 von 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
    Frag FixBot
  6. Astak Mole Microphone  Replacement, Microphone: Schritt 6, Bild 1 von 1
    • Remove microphone from its holder on the bottom section of the casing.
    Frag FixBot
  7. Astak Mole Microphone  Replacement: Schritt 7, Bild 1 von 1
    • Access microphone and assess damage.
    Frag FixBot
  8. Astak Mole Microphone  Replacement: Schritt 8, Bild 1 von 1
    • Remove microphone input with metal spudger. Be sure to sever electrical adhesive in order to separate input and output.
    • It is advised to re-apply adhesive to the cable once the new microphone cable is replaced.
    Frag FixBot
Abschluss
USF Tampa, Team 2-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 26
Insgesamt: 472
