Zum Hauptinhalt wechseln
Astro Mixamp Control Button Replacement
Was du brauchst
    1. Astro Mixamp Control Button Replacement, Panel Dial: Schritt 1, Bild 1 von 2 Astro Mixamp Control Button Replacement, Panel Dial: Schritt 1, Bild 2 von 2
      • Grip the dial tightly and pull straight off the device.
      • Repeat for the second dial
      Frag FixBot
      Kommentar hinzufügen
    2. Astro Mixamp Control Button Replacement: Schritt 2, Bild 1 von 2 Astro Mixamp Control Button Replacement: Schritt 2, Bild 2 von 2
      In diesem Schritt verwendetes Werkzeug:
      • Using tweezers, remove the spacer nuts and washers from each dial post.
      Frag FixBot
    1. Astro Mixamp Control Button Replacement, Outer Casing: Schritt 3, Bild 1 von 2 Astro Mixamp Control Button Replacement, Outer Casing: Schritt 3, Bild 2 von 2
      • Before opening your device, ensure the device is not on or connected to the charging cable.
      • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
      • Pull the rubber foot free of the plastic casing.
      Frag FixBot
    2. Astro Mixamp Control Button Replacement: Schritt 4, Bild 1 von 1
      • Use a screwdriver to remove the screw from the rear casing.
      Frag FixBot
    3. Astro Mixamp Control Button Replacement: Schritt 5, Bild 1 von 1
      • Gently lift the rear casing from the device.
      Frag FixBot
    1. Astro Mixamp Control Button Replacement, Motherboard: Schritt 6, Bild 1 von 3 Astro Mixamp Control Button Replacement, Motherboard: Schritt 6, Bild 2 von 3 Astro Mixamp Control Button Replacement, Motherboard: Schritt 6, Bild 3 von 3
      • Remove the four screws that hold the motherboard in place.
      • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
      Frag FixBot
    2. Astro Mixamp Control Button Replacement: Schritt 7, Bild 1 von 1
      • Gently pull the motherboard from the front cover.
      Frag FixBot
    1. Astro Mixamp Control Button Replacement, Control Button: Schritt 8, Bild 1 von 2 Astro Mixamp Control Button Replacement, Control Button: Schritt 8, Bild 2 von 2
      • Gently insert a metal spudger under a control button housing.
      • Do not pry the button housing from the front panel, this can cause damage to the button.
      • Rotate the control button around the marked pin.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 2,096
