Einleitung
Use this guide to remove control buttons for cleaning or replacement.
Was du brauchst
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, remove the spacer nuts and washers from each dial post.
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Gently insert a metal spudger under a control button housing.
Rotate the control button around the marked pin.
3 weitere Personen haben diese Anleitung absolviert.
