Einleitung
Use this guide when the device motherboard needs to be removed. (Soldering Required)
Was du brauchst
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using tweezers, remove the spacer nuts and washers from each dial post.
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Eine weitere Person hat diese Anleitung absolviert.
