Zum Hauptinhalt wechseln
Asus A52F RAM Replacement
Was du brauchst
  1. Asus A52F RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Asus A52F RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus A52F RAM Replacement: Schritt 2, Bild 1 von 2 Asus A52F RAM Replacement: Schritt 2, Bild 2 von 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
    Frag FixBot
  3. Asus A52F RAM Replacement, Lower Case: Schritt 3, Bild 1 von 3 Asus A52F RAM Replacement, Lower Case: Schritt 3, Bild 2 von 3 Asus A52F RAM Replacement, Lower Case: Schritt 3, Bild 3 von 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
    Frag FixBot
  4. Asus A52F RAM Replacement: Schritt 4, Bild 1 von 2 Asus A52F RAM Replacement: Schritt 4, Bild 2 von 2
    • Slide the back panel away and remove the panel.
    Frag FixBot
  5. Asus A52F RAM Replacement, RAM: Schritt 5, Bild 1 von 1
    • Gently push the metal retaining arms away from the center of the RAM module.
    Frag FixBot
  6. Asus A52F RAM Replacement: Schritt 6, Bild 1 von 3 Asus A52F RAM Replacement: Schritt 6, Bild 2 von 3 Asus A52F RAM Replacement: Schritt 6, Bild 3 von 3
    • The RAM should now be sticking up at a 30° angle.
    • Carefully grab the top edge of the RAM and gently pull it it out at it's angle.
    Frag FixBot
  7. Asus A52F RAM Replacement: Schritt 7, Bild 1 von 1
    • Repeat removal process for the RAM underneath.
    Frag FixBot
  8. Asus A52F RAM Replacement: Schritt 8, Bild 1 von 2 Asus A52F RAM Replacement: Schritt 8, Bild 2 von 2
    • To insert new RAM line up notch in the connector and slide in at a 30° angle.
    • RAM only goes in one way!
    • Push straight down until the metal clips on both sides click into place
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S5-G1, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 1,298
