Einleitung
This guide is meant to assist you in replacing the battery of your ASUS L410MA-MH09-CA device. Remember to first attempt the steps in our troubleshooting guide. If you have exhausted these steps, then it's time to follow this replacement guide.
Removing the battery is a task with minimal risk to the device. Remember to wear an ESD wrist strap anytime you're opening an electronic device.
Was du brauchst
Remove all ten 6 mm Phillips #1 screws that secure the lower case.
Insert an opening pick in the gap between the lower case and chassis.
Slide the opening pick around the entire perimeter of the laptop until the lower case fully releases.
Remove the lower case.
For optimal performance, after completing this guide, calibrate your newly installed battery.
2 weitere Personen haben diese Anleitung absolviert.
