Zum Hauptinhalt wechseln
Asus Padfone 2 Camera Replacement
Was du brauchst
  1. Asus Padfone 2 Camera  Replacement, Power Down Device: Schritt 1, Bild 1 von 1
    • Hold down the power button.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus Padfone 2 Camera  Replacement, Remove Back Plate: Schritt 2, Bild 1 von 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: Schritt 2, Bild 2 von 3 Asus Padfone 2 Camera  Replacement, Remove Back Plate: Schritt 2, Bild 3 von 3
    • Use plastic opening tool to pry off the back cover of the phone.
    Frag FixBot
  3. Asus Padfone 2 Camera  Replacement, Battery Removal: Schritt 3, Bild 1 von 3 Asus Padfone 2 Camera  Replacement, Battery Removal: Schritt 3, Bild 2 von 3 Asus Padfone 2 Camera  Replacement, Battery Removal: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
    Frag FixBot
  4. Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: Schritt 4, Bild 1 von 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: Schritt 4, Bild 2 von 3 Asus Padfone 2 Camera  Replacement, Remove Internal Back Plate: Schritt 4, Bild 3 von 3
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
    Frag FixBot
  5. Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: Schritt 5, Bild 1 von 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: Schritt 5, Bild 2 von 3 Asus Padfone 2 Camera  Replacement, Disconnect Motherboard: Schritt 5, Bild 3 von 3
    • Disconnect four plugs to the motherboard using tweezers.
    • Lift up green motherboard.
    Frag FixBot
  6. Asus Padfone 2 Camera  Replacement, Removing Camera: Schritt 6, Bild 1 von 2 Asus Padfone 2 Camera  Replacement, Removing Camera: Schritt 6, Bild 2 von 2
    • Remove camera from back of the motherboard with tweezers.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Erica
482 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 5-4, Mcgee Fall 2014 Mitglied von USF Tampa, Team 5-4, Mcgee Fall 2014
USFT-MCGEE-F14S5G4
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 31
Insgesamt: 2,290
