Zum Hauptinhalt wechseln
Asus ROG Ally Macro Buttons Replacement
Was du brauchst
  1. Asus ROG Ally Macro Buttons Replacement, Prepare your device for disassembly: Schritt 1, Bild 1 von 3 Asus ROG Ally Macro Buttons Replacement, Prepare your device for disassembly: Schritt 1, Bild 2 von 3 Asus ROG Ally Macro Buttons Replacement, Prepare your device for disassembly: Schritt 1, Bild 3 von 3
    • Let your device's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Completely power off your device and unplug all cables.
    • Consider laying your device on a soft cloth to prevent scratching or damaging the screen during your repair.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus ROG Ally Macro Buttons Replacement, Unfasten the back cover: Schritt 2, Bild 1 von 2 Asus ROG Ally Macro Buttons Replacement, Unfasten the back cover: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • Use a Phillips #0 screwdriver to remove the five 17.2 mm‑long screws securing the top edge and bottom corners of the back cover.
    • Use a Phillips #0 screwdriver to fully loosen the remaining captive screw at the center of the bottom edge. This should create a small gap between the back cover and chassis.
    • Don't try to remove this screw.
    Frag FixBot
  3. Asus ROG Ally Macro Buttons Replacement, Insert an opening pick: Schritt 3, Bild 1 von 3 Asus ROG Ally Macro Buttons Replacement, Insert an opening pick: Schritt 3, Bild 2 von 3 Asus ROG Ally Macro Buttons Replacement, Insert an opening pick: Schritt 3, Bild 3 von 3
    • Insert the flat edge of an opening pick between the bottom edge of the back cover and chassis, near the captive screw.
    • Angle the pick upward and push it under the back cover.
    Frag FixBot
  4. Asus ROG Ally Macro Buttons Replacement, Release the back cover's clips: Schritt 4, Bild 1 von 3 Asus ROG Ally Macro Buttons Replacement, Release the back cover's clips: Schritt 4, Bild 2 von 3 Asus ROG Ally Macro Buttons Replacement, Release the back cover's clips: Schritt 4, Bild 3 von 3
    • Plastic clips secure the perimeter of the back cover. You should feel and hear them release during this step.
    • Slide the opening pick along the bottom edge and around the corners of the back cover to release the clips securing it.
    • Keep the pick at an upward angle under the back cover to help release the clips.
    Frag FixBot
  5. Asus ROG Ally Macro Buttons Replacement, Remove the back cover: Schritt 5, Bild 1 von 3 Asus ROG Ally Macro Buttons Replacement, Remove the back cover: Schritt 5, Bild 2 von 3 Asus ROG Ally Macro Buttons Replacement, Remove the back cover: Schritt 5, Bild 3 von 3
    • Lift the bottom edge of the back cover off the chassis to release the remaining clips.
    • Remove the back cover.
    • During reassembly, lay the back cover onto your device and firmly push down around the perimeter to engage the clips.
    Frag FixBot
  6. Asus ROG Ally Macro Buttons Replacement, Unfasten the macro buttons: Schritt 6, Bild 1 von 2 Asus ROG Ally Macro Buttons Replacement, Unfasten the macro buttons: Schritt 6, Bild 2 von 2
    • When removing the screws, be careful not to lose the springs under them. They can easily eject!
    • Use a Phillips #000 screwdriver to remove the 2.9 mm‑long screw securing each macro button (two total).
    Frag FixBot
  7. Asus ROG Ally Macro Buttons Replacement, Remove the springs: Schritt 7, Bild 1 von 3 Asus ROG Ally Macro Buttons Replacement, Remove the springs: Schritt 7, Bild 2 von 3 Asus ROG Ally Macro Buttons Replacement, Remove the springs: Schritt 7, Bild 3 von 3
    • Use tweezers or your fingers to remove the springs from their screw posts.
    Frag FixBot
  8. Asus ROG Ally Macro Buttons Replacement, Unclip the macro button: Schritt 8, Bild 1 von 3 Asus ROG Ally Macro Buttons Replacement, Unclip the macro button: Schritt 8, Bild 2 von 3 Asus ROG Ally Macro Buttons Replacement, Unclip the macro button: Schritt 8, Bild 3 von 3
    • Two rectangular clips secure the macro buttons to the back cover.
    • Use the flat end of a spudger or your fingers to push in the clips securing one of the macro buttons.
    Frag FixBot
  9. Asus ROG Ally Macro Buttons Replacement, Remove the macro button: Schritt 9, Bild 1 von 2 Asus ROG Ally Macro Buttons Replacement, Remove the macro button: Schritt 9, Bild 2 von 2
    • Remove the macro button.
    Frag FixBot
  10. Asus ROG Ally Macro Buttons Replacement, Remove the other macro button: Schritt 10, Bild 1 von 2 Asus ROG Ally Macro Buttons Replacement, Remove the other macro button: Schritt 10, Bild 2 von 2
    • Repeat the last two steps to unclip and remove the other macro button.
    • During reassembly, firmly push the macro buttons into place to engage their clips. You should feel the clips click as they engage.
    Frag FixBot
Abschluss
Spencer Day
196.112 Reputation
1.243 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
27.624 Anleitungen geschrieben
1 Kommentar zur Anleitung
One of the screws got damaged, i do not know how its it called or how i can find it. If you have that information I would appreciate it.
Damian Moreno - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 28
Letzte 30 Tage: 106
Insgesamt: 2,037
