Zum Hauptinhalt wechseln
Asus ROG Strix GL702VS LCD Screen (Display) Replacement
Was du brauchst
  1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): Schritt 1, Bild 1 von 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): Schritt 1, Bild 2 von 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): Schritt 1, Bild 3 von 3
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 2, Bild 1 von 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 2, Bild 2 von 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 2, Bild 3 von 3
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
    Frag FixBot
  3. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 3, Bild 1 von 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 3, Bild 2 von 2
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
    Frag FixBot
  4. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 4, Bild 1 von 1
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
    Frag FixBot
  5. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 5, Bild 1 von 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 5, Bild 2 von 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 5, Bild 3 von 3
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
    Frag FixBot
  6. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 6, Bild 1 von 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 2,320
