Zum Hauptinhalt wechseln
Asus Zenbook UX550GE-XB71T Battery Replacement
Was du brauchst
  1. Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Asus Zenbook UX550GE-XB71T Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn computer off and disconnect it from power.
    • Flip it over so the backside is facing you.
  2. Asus Zenbook UX550GE-XB71T Battery Replacement: Schritt 2, Bild 1 von 2 Asus Zenbook UX550GE-XB71T Battery Replacement: Schritt 2, Bild 2 von 2
    • Using the T5 Torx screwdriver, remove the ten screws under the computer.
    • Gently remove the back cover from the device.
  3. Asus Zenbook UX550GE-XB71T Battery Replacement: Schritt 3, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the four screws along the battery.
  4. Asus Zenbook UX550GE-XB71T Battery Replacement: Schritt 4, Bild 1 von 3 Asus Zenbook UX550GE-XB71T Battery Replacement: Schritt 4, Bild 2 von 3 Asus Zenbook UX550GE-XB71T Battery Replacement: Schritt 4, Bild 3 von 3
    • Disconnect the ribbon cable by pushing upwards on the ZIF connector.
  5. Asus Zenbook UX550GE-XB71T Battery Replacement: Schritt 5, Bild 1 von 1
    • Disconnect and remove the battery from the device.
Abschluss
For optimal performance, after completing this guide, calibrate your newly installed battery.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 41
Insgesamt: 1,061
