Zum Hauptinhalt wechseln
August Smart Lock Accelerometer Replacement
Was du brauchst
    1. August Smart Lock Accelerometer Replacement, Accelerometer: Schritt 1, Bild 1 von 3 August Smart Lock Accelerometer Replacement, Accelerometer: Schritt 1, Bild 2 von 3 August Smart Lock Accelerometer Replacement, Accelerometer: Schritt 1, Bild 3 von 3
      • Flip device over so the black bottom is facing you.
      • Undo latches on both sides to remove the metal cover.
      • Using a Phillips #0 screwdriver, remove the black screws to release the back cover.
      • To unscrew all of the screws, you will need to close the latches again.
      • When you lift off the cover, be careful not to lift to far up. The cover contains the speaker which is connected to the motherboard.
      Frag FixBot
      Kommentar hinzufügen
    2. August Smart Lock Accelerometer Replacement: Schritt 2, Bild 1 von 3 August Smart Lock Accelerometer Replacement: Schritt 2, Bild 2 von 3 August Smart Lock Accelerometer Replacement: Schritt 2, Bild 3 von 3
      • Grab the gears and lift them up to remove from the device
      Frag FixBot
    3. August Smart Lock Accelerometer Replacement: Schritt 3, Bild 1 von 3 August Smart Lock Accelerometer Replacement: Schritt 3, Bild 2 von 3 August Smart Lock Accelerometer Replacement: Schritt 3, Bild 3 von 3
      • Remove the (3) three silver screws by the motor using a Phillips #0 screwdriver.
      • Disconnect the speaker plug from the motherboard
      • Disconnect the battery plugs from the motherboard.
      Frag FixBot
    4. August Smart Lock Accelerometer Replacement: Schritt 4, Bild 1 von 1
      • Once the speaker is disconnected, remove the back cover.
      • Lift up the motherboard and motor assembly out of the device.
      Frag FixBot
    5. August Smart Lock Accelerometer Replacement: Schritt 5, Bild 1 von 2 August Smart Lock Accelerometer Replacement: Schritt 5, Bild 2 von 2
      • Locate the Accelerometer. It is attached to the motherboard by a ribbon.
      • Lift up the black tab to remove the ribbon from the motherboard.
      Frag FixBot
Abschluss
8 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S11-G6, Passmore Fall 2017 Mitglied von USF Tampa, Team S11-G6, Passmore Fall 2017
USFT-PASSMORE-F17S11G6
4 Mitglieder
15 Anleitungen geschrieben
7 Kommentare zur Anleitung
Any idea where can I get a new accelerometer to complete this repair?
Thai Nguyen - Antwort Teilen
Where can we get a new accelerometer. My phone was not connecting because of the ribbon was broken inside
Dinesh Sharma - Antwort Teilen
Same as above…. where to locate an accelerometer??
osallabe - Antwort Teilen
Did anyone find out where to buy the part?
LBurd - Antwort Teilen
Where can I find one
Jeff Wasilewski - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 63
Insgesamt: 8,908
