Zum Hauptinhalt wechseln
BRCK v1 Modem Replacement
Was du brauchst
    1. BRCK v1 Modem  Replacement, Top Cover: Schritt 1, Bild 1 von 1
      • Place the face of the device showing BRCK face up.
      Frag FixBot
      Kommentar hinzufügen
    2. BRCK v1 Modem  Replacement: Schritt 2, Bild 1 von 1
      • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
      Frag FixBot
    3. BRCK v1 Modem  Replacement: Schritt 3, Bild 1 von 1
      • Remove the top cover.
      Frag FixBot
    1. BRCK v1 Modem  Replacement, Modem: Schritt 4, Bild 1 von 1
      • Cut the black zip tie holding the modem down.
      • Caution By cutting the zip tie, you void any manufacturer warranty you may have on the device.
      Frag FixBot
    2. BRCK v1 Modem  Replacement: Schritt 5, Bild 1 von 1
      • Remove the connection located on the edge of the modem.
      Frag FixBot
    3. BRCK v1 Modem  Replacement: Schritt 6, Bild 1 von 2 BRCK v1 Modem  Replacement: Schritt 6, Bild 2 von 2
      • Slightly lift the modem to reveal the brown ribbon connector and metal connection plate, located on the bottom of the modem.
      Frag FixBot
    4. BRCK v1 Modem  Replacement: Schritt 7, Bild 1 von 3 BRCK v1 Modem  Replacement: Schritt 7, Bild 2 von 3 BRCK v1 Modem  Replacement: Schritt 7, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Using your tweezers, gently push on the metal plate and slide it down toward the base of the modem to release the locking mechanism.
      • Lower the plate and gently pull the ribbon out of the face plate.
      • Caution Be extremely gentle while preforming this step. The ribbon is brittle and prone to breaking if bent too much. Make sure you go slowly so that you do not damage the device.
      Frag FixBot
    5. BRCK v1 Modem  Replacement: Schritt 8, Bild 1 von 2 BRCK v1 Modem  Replacement: Schritt 8, Bild 2 von 2
      • Remove the modem from the device.
      Frag FixBot
Abschluss
Cal Poly, Team 12-3, Lancaster Spring 2015 Mitglied von Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Mitglieder
35 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 17
Insgesamt: 504
