Zum Hauptinhalt wechseln
Back Panel
Was du brauchst
  1. Back Panel, Back Panel: Schritt 1, Bild 1 von 1
    • Flip the laptop so that the back is facing upwards.
    • Locate the small screw on the back that holds the "L" shaped panel.
    • Using a 0 Phillip Screwdriver (4.0x4.7mm sized screw), unscrew the screw. It will not become detached from the panel but it will allow you to remove the back panel.
    Frag FixBot
    Kommentar hinzufügen
  2. Back Panel: Schritt 2, Bild 1 von 3 Back Panel: Schritt 2, Bild 2 von 3 Back Panel: Schritt 2, Bild 3 von 3
    • Using a plastic opening tool, pry the back panel from the computer, going all the way around it.
    • This will take a good amount of force and you will hear clicking noises as you snap each of the connections out of place.
    Frag FixBot
  3. Back Panel: Schritt 3, Bild 1 von 1
    • Once the back panel is completely removed you will have access to the RAM and many other connections in the computer.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 12
Letzte 30 Tage: 55
Insgesamt: 963
