Einleitung
The screen on basis peak is essential to the functionality of this device. The screen displays all of the features available in the device. The screen of the Basis Peak can be replaced if there are any issues with the device's display by following this guide. The disassemble should not be a problem for there is only one way to remove the screen.
Was du brauchst
Flip the watch over and orient it such that the buckle is away from you and the back panel is revealed.
Remove the four base screws using a size 2 TORX screwdriver to separate the back plate from the frame.
Disconnect the ribbon cable on the left side of the motherboard by using a spudger.
Use a spudger and apply pressure to the white plastic wall to the right of the motherboard. Use this to lever the electronics out of the frame.
Flip over the motherboard complex and gently remove the screen with your fingers.
