Zum Hauptinhalt wechseln
Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement
Was du brauchst
  1. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Spark Plug Disconnection: Schritt 1, Bild 1 von 2 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Spark Plug Disconnection: Schritt 1, Bild 2 von 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: Schritt 2, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: Schritt 2, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: Schritt 2, Bild 3 von 3
    • Lift to raise the front end of the brush cutter.
    • Place a jack stand or other secure support under the deck to prevent the brush cutter from tipping forward.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 3, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 3, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 3, Bild 3 von 3
    • Use a 13/16" socket to remove the bolt securing the blade.
    • If needed, wedge a wood block between the blade and the deck to prevent the blade from turning.
    • During reassembly, make sure the blade is fully seated on the spindle, and use a torque wrench to tighten the bolt to 33-38 ft lbs.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 4, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 4, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 4, Bild 3 von 3
    • Wear gloves or be careful when handling the blade.
    • Remove the bolt and friction washer, and remove the blade.
    • Use a new bolt and washer when replacing the blade.
    • If the large cylindrical blade adapter falls off the spindle, check to make sure the key is correctly positioned inside the adapter, and then align the key with the notch on the spindle when installing it.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 5, Bild 1 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 5, Bild 2 von 3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 5, Bild 3 von 3
    • Use a 3/8" socket or wrench to remove the four 21 mm bolts securing the top cover to the deck.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 6, Bild 1 von 2 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 6, Bild 2 von 2
    • Lift and remove the top cover.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: Schritt 7, Bild 1 von 1
    • Using a 9/16” socket or wrench, make sure the bolt at the top of the spindle is tight.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jeff Suovanen
428.711 Reputation
259 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.298 Anleitungen geschrieben
Ein Kommentar
how about a part number for the replacement blade that you show how to change,
ALLAN - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 53
Insgesamt: 2,291
