Einleitung
Instructions for removing the rear guard/cover to access internal components for service.
Was du brauchst
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2" socket or wrench to remove the two 26 mm bolts securing the rear guard to the back end of the brush cutter.
Raise and support the back end of the brush cutter—or tip it carefully onto its side—in order to access the bottom cover.
Use a 3/8” socket or wrench to remove the four 21 mm bolts securing the rear guard.
Remove the guard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
